Head swap with ST1000LM035 (mobile HDD)
recovery
Postby recovery » 19.07.17, 17:36
We recently buy a donor for a ST1000LM035 1RK172-568. Exactly same numbers on the label: same PN, same firmware. The hard drive was very different from the customer's drive. One more platter, head map 1,2,3 (customer: 0,1) and... a toe integrated in the chassis, preventing the releasing of the heads arm.
And... Some screws are not Torx (see the topic viewtopic.php?f=154&t=9346).
We keep thinking about a good way to do a head swap with these drives. :shockable: Do you have any tips?
Re: Head swap with ST1000LM035 (mobile HDD)
Postby Amarbir[CDR-Labs] » 20.07.17, 18:17
Well,
I am waiting for a tool for these drives i plan to make a video for all Acelab Customers with the Help of Acelab team ,Once i Shoot The Video i plan to show to our team for approval and then release it ,Hope that helps ,I have Already Replied To Your Screwdriver Question Properly
Blizzard
Postby Blizzard » 21.07.17, 01:25
Search for "Video Guide for Sea 2.5 Slim Set" on YouTube and you can see a very good demonstration.
Paradog84
Postby Paradog84 » 22.07.17, 22:07
Simple - you do not swap the heads - you swap the platters ;;)
Postby Amarbir[CDR-Labs] » 23.07.17, 16:20
Paradog84 wrote:Source of the post Simple - you do not swap the heads - you swap the platters ;;)
Well,
Its Better To Swap Heads Then Platters
recovery
Postby recovery » 25.07.17, 11:09
Amarbir[CDR-Labs] wrote:Source of the post Well,
Thank you, all helps are welcome :D
Yes, thank you!
Blizzard wrote:Source of the post Search for "Video Guide for Sea 2.5 Slim Set" on YouTube and you can see a very good demonstration.
Thank you, so I think we will need this tool, it seems to be mandatory for these hard drives. Thank you for the video.
Users browsing this forum: Bing [Bot] and 11 guests
