Hi everybody
The problem is this: when trying to clean smart , it gives the following error:
The HDD ID:
Model : WDC WD5000LPCX-24VHAT0
Serial : WD-WXF1A86KC19D
Firmware : 02.01A02
Capacity : 500 Gb (976 773 168)
Techno mode key
SA SPT.................................. : 1437
Modules directory address............... : 98 041
ROM Modules:
ROM version............................. : 03.3VJ
ROM F/W version......................... : 0003003V
Overlay F/W version..................... : 03.3WJ
Servo F/W version....................... : B5.0D
Service area:
Summary Error Log....................... : Feature value set error Device Error Detected: "VSC ERR DRM LOG NOT LOADED"
Summary Error Log....................... : Ok
Self Test Log........................... : Feature value set error Device Error Detected: "VSC ERR DRM LOG NOT LOADED"
Self Test Log........................... : Ok
Other S.M.A.R.T. logs................... : Feature value set error Device Error Detected: "VSC ERR DRM LOG NOT LOADED"
Other S.M.A.R.T. logs................... : Ok
HDD ID reading (RAM).................... : Ok
Thank you to help..
WD smart error
- DataMedics
Re: WD smart error
So why are you trying to clear SMART? Trying to "refurbish" and sell on eBay?
- cengizgulum
Re: WD smart error
Yes , I am trying to refurbish it but not to sell it on eBay..
is it impossible to fix ?
- Amarbir[CDR-Labs]
Re: WD smart error
Very interested to know from roman and filipp how to solve this i have a similar case at hand
- DataMedics
Re: WD smart error
cengizgulum wrote:Source of the post is it impossible to fix ?
Probably not impossible, but certainly not worth the time to just mask a symptom of a failing drive.
- cengizgulum
Re: WD smart error
hello Amarbir,
I solved the problem by applying "slow responding changes cancel" under "work with service area" (! not "work with ram")
Re: WD smart error
Weird
I have solved it RESTORING the slow responding changes
except restoring the Relo List (though I don't think it makes difference)
FAsTec is the owner of the Italian popular brand RecuperoDati299
https://www.RecuperoDati299euro.it
