I have trouble accessing a Seagate ST2000DM001 FW:CC26, it reports "Drive not ready" and "PIO Register access timeout (1)" all the time.
The drive seems to spin up nice, no sounds of any kind.
Can't find any info regarding the issue in the documentation.
This is for training purposes only, no critical data. Any help appreciated, thanks.
-Espen
Seagate ST2000DM001 "PIO Register access timeout (1)"
- DataMedics
Re: Seagate ST2000DM001 "PIO Register access timeout (1)"
Probably has issues with the media cache and/or sector re-allocation. Couple bits of information you need to provide.
First, can you provide a terminal log. Second, what's happening with the status registers at the bottom when you're getting this error? Is the BSY light getting stuck on?
Well, I noticed that the drive reported capacity of 0 GB, and tried the "Solution for the "Translation violation (0 GB)" problem" which actually failed. Then after some reading I decided to try the "Solution for the HDD Lock (LED: 000000CC) problem" since the HDD failed to become ready.
The hard drive now reports the correct capacity, and the "PIO Register access timeout (1)" message has gone. So it seems to have fixed something.
There are however still some issues, example when trying to read S.M.A.R.T info, it reports "Error reading S.M.A.R.T. (Attribs) HDD Redynes timeout (100000)" (a small typo in the err.msg btw)
Regarding the status registers, DRD and DSC is green, no stuck BSY or any red lights.
The log is here:
Thanks for helping! It's a long learning process
-Espen
The log is here:
Code: Select all
Selected family......................... : 58, Grenada
Model by ID............................. : <HDD ID NOT READ>
Loading default settings!
Then press OK!
Tech Key...
Requesting FW Pkg ver ........ GPG17C.CCD2.CB0487.CC26
Detecting Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 4
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C001000 - 0x0001FFFF (0x0000000F)
Reading Registry File...
Parsing Registry File...
Media Cache
MC : enabled
MC Size : 0x43DBB0
MCMT Ver : MCMTV05
ID Len
0 36 Reserved Defect Table (SA defect table)
3 7782 Primary Defect File (P-List))
8 4800
B 1000
C 122880 Serial Port Test Results File (Self Scan Log)
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
2B 10118 R/W Operating Parameters (translator, etc)
33 4576
39 8192
3A 4
3D 3072
3E 3072
3F 4576
40 7
41 2180
42 4096
43 10241
44 1357032
45 226172
46 226172
47 226172
48 226172
49 226172
4A 226172
4B 8192
4F 14336
Collecting DT Infos...
ID MemOffs Len
0 40030200 40944 Read Adaptive Parameters File (RAP)
1 40030000 512 Controller Adaptive Parameters File (CAP)
4 1D400 7168 Servo Adaptive Parameter File (SAP)
40002000 13288
total 20456
A 25EA94 1024 Seek Profile
13 401291C0 1440 Dependent Zone Table for User Area
14 40129760 120 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1D 40030220 424 VBAR Configuration File
1E 400305B8 4016 Zone Format Parameters File
26 40126CF0 9424
27 40126AF8 504
ID MemOffs Len
2 400303C8 496 Zone Table
40002000 13288
total 20456
6 1915C40 81964 Servo Flaw Table
16 40030200 32 Drive Configuration Table
17 400319A0 2016 Temperature Control Configuration
1F 4032C8E8 4500 RW working user preamp table
20 4032DA80 150 RW working system preamp table
26 40126CF0 9424
27 40126AF8 504
Collecting DT Infos completed
Reading autotuning buffer............... Ok
Searching volume 3 file table in RAM.... Ok
Searching volume 0 file table in RAM.... Ok
Searching SMP RAM FID in RAM............ Ok
Searching Non Resident G-List FID in RAM Ok
Searching CFW OVL FID in RAM............ Ok
System Files I/O method detection... ATA(direct)Thanks for helping! It's a long learning process
-Espen
- DataMedics
That's not the terminal, that's just the PC-3000 log. Need to see what the drive is reporting in the terminal tab when it's powered on.
Espen, for Seagate HDDs you want to connect the PC USB terminal adapter. There is a picture in the Seagate_1 manual (fig. 3.3) if you need it. Once you have the terminal adapter connected and working power on the hard drive and you should see output in the "terminal tab" that @DataMedics is referring to.
Here is what the terminal log displays when I'm powering on the drive:
But I noticed the following when looking at the power monitor:
Looks very similar to the "3.5? ST2000DM001 (Grenada). With Voltage Graph. Weak head" in this article: http://blog.acelab.eu.com/pc-3000-p ... ision.html
-Espen
Code: Select all
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA ResetBut I noticed the following when looking at the power monitor:
-Espen
