Dear Friend ,
Good Day ...
I have an SSD SCAN DISK X 300S 256 GB OPAL ,When i connected in pc3000 is come ready state ,But when click to ready iD its gone busy .. Any idea to recover the data from this
Please share our suggestions
thanks
Re: SCAN DISK X 300S 256 GB OPAL
For recovery of Marvell-based Sandisk SSD we need to use new terminal v3, that we are going to release in next couple of month. New terminal will allow to upload LDR through it and get access to user data on drive. Right now, your drive is supported, but with current version of ACELab terminal it's not possible to work normally.
i Received same problem one SSD 512 GB any solution in this time.
MODEL-SD7SB7S-512G-1001
SSD X300 SATA
SSD X300 SATA
Thanks & Regard
Bikram Singh
Bikram Singh
Complere solution for Marvell based SSD drives will be ready in next release of PC-3000 SSD closer to the Spring-Summer 2018.
Hello Roman how are you ?
how much is the cost for the new terminal, you have the price
Hello Diego,
New terminal is under production, but it's not in the stock yet. Anyway, solution for Marvell-based Sandisk drives will not required Terminal. It would be a different solution
