"broken" in DE operation status section instead of "complete"
ThomasH
Postby ThomasH » 09.06.17, 15:44
After the 6.3 update, I'm DE is commonly reporting cloning processes as 'broken' instead of 'complete' ... a majority of the time I think.
Is this just a glitch, or does it indicate something?
My normal method of cloning is to first build maps of the desired files, sort to sequential order, then clone the selection. I'm not sure if I've seen it occur when just cloning normally without selectivity. I have never seen this before the 6.3 update.
Re: "broken" in DE operation status section instead of "complete"
Postby digitalsupport » 09.06.17, 15:48
+1 I also noted that.
But no errors, tried the same job on 6.2 where the final masseage is "complete"
Postby digitalsupport » 12.06.17, 11:21
This issue is solved in DE 5.6.4
Return to “Data Extractor”
