Hi, I connected wd10jmvw-11s5xs1 by USB and serial cable and I got the following errors:
Expand viewDisplayed errors
Techno mode key Techno mode key......................... : Ok
Debug Stop Code reading................. : VSC Status reading error Data receiving error COM port reading timeout (rq: 523 / rd: 0):
RAM: HDD Info reading........................ : HDDs RAM reading error VSC data reading error Sectors receiving error Data receiving error COM port reading timeout (rq: 515 / rd: 8 ): BE EF 01 00 00 00 12 40
Zone allocation table................... : HDDs RAM reading error VSC data reading error Sectors receiving error Data receiving error COM port reading timeout (rq: 515 / rd: 8 ): BE EF 01 00 00 00 12 40
ROM: Read ROM................................ : HDDs ROM reading error VSC data reading error Sectors receiving error Data receiving error COM port reading timeout (rq: 515 / rd: 8 ): BE EF 01 00 00 00 12 40
Service area: Permanent overlay....................... : Not loaded SA dir reading (ABA/CHS)................ : Device error detected SA Access............................... : NONE
Collapse view
Spindle motor starts and no weird sounds. Is the board broken?
Hello , Remove board from HDA assembly .Then Connect To USB and Serial Cable Wait For 5 Minutes Then Run USB/Serial Western Digital Tool .Select Kernel Mode From Mode Selection on top ,Then Please Post Result Here .Once if it reaches kernel mode properly backup complete rom and also rom modules .Please tell me the USB pcb no so that i can assist you further
RAM: HDD Info reading........................ : Ok Heads number............................ : 1 Cyl Count............................... : 256
ROM: Read ROM................................ : Ok ROM Data size........................... : 256 Kb Flash ROM dir reading................... : Ok (Active) Flash ROM dir reading (Ext)............. : Ok Modules directory address............... : 73 265 SA regions address...................... : by default Module 02 access........................ : Granted SA Translator loading................... : Ok
ROM Modules: ROM version............................. : 03.78C ROM F/W version......................... : 00030078 Overlay F/W version..................... : 03.78C Servo F/W version....................... : TP.4D
Heads configuration..................... : by map Heads number............................ : 4 Heads number in use..................... : 4 Switched off heads...................... : No Heads map............................... : 0,1,2,3
