Hi.
I have a wd40nmzw-11gx6s1 drive with the G80008 rom version.
Whit SED
I follow the steps http://blog.acelab.eu.com/pc-3000-h ... rives.html
When I try to load the dir into ram from a file it gives me this error
Statc mdl writing error device detected error: "vsc err inv func code req"
If I try to load the dir into ram from sa it gives me this error
Static module reading error device deteted: "" vsc err inv func code req "
I need the module 11 FW G8008 to read the other modules
Thank you
I need module 11 wd40nmzw-11gx6s1 fw g80008
Re: I need module 11 wd40nmzw-11gx6s1 fw g80008
Just a double check with you have you disabled SA access in rom so that you can easily load overlay modules like 11 no
Hello Jaime,
Unfortunately haven't a resources with such f/w version.
I don't have it but sometimes Donor Drives will send it if you request it using their contact form and include the SKU number. Here are their listings for WD40NMZW-11GX6S1
Jaime, try to block module 30 access in ROM, then restart the drive ant load Dir and loader from RAM.
Hello Maxim.
I have blocked module 30, power off power on, start in kernel mode them load dir in ram, but send me the same error
" Statc Mdl writing error Device Error Detected: "VSC ERR INV FUNC CODE REQ" "
In normal mode with module 30 blocked, try to load dir in ram, but does not respond
any other suggest
any other suggest
Jaime, please contact us creating a ticket in ts.acelab.eu.com with teamviewer details.
Hi max ,
Time to take a update and a quote from kate
Yes, new update have some new features, which can be useful for data recovery
Which kernel family is the WD40NMZW part of? Is it the newly supported "Blade"?
J
J
I've been informed that these are "SpyGlass" family, and it is not possible to access the SA via USB, but potentially OK to access via SATA channels. What is the most appropriate kernel family to boot into for these, PebbleB ?
J
J
