I get the following error when I try to recover F3 translator...
osity
Postby osity » 14.04.17, 05:02
Seagate ST9500320AS
I have what seems to be a translator issue.
I tried to regen translator which completed but I could still not access sectors located at the end of the drive.
Afterwards, I tried to recover the translator and I get a lot of the following type of errors which continue seemingly forever:
Start scanning...
"Fork" searching: 0 - 976773167
Verify sectors ext error Device error detected "UNC"
PRd: Err Rd Ph Sect 422C:3:21E(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 422C:3:21E(1)! Tech state 0x72, 0x03110081
LBA : 123277186
"Fork" searching: 123277187 - 976773167
PRd: Err Rd Ph Sect 422C:3:26B(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 422C:3:26B(1)! Tech state 0x72, 0x03110081
LBA : 123277263
Currently I can read first half of sectors but I get UNC error on the end part of the drive.
I'm guessing I have to manually update a list for a manual translator recovery attempt. I've never done this.
Can anyone point me in the right direction?
Re: I get the following error when I try to recover F3 translator...
Postby DataMedics » 15.04.17, 15:46
You need to let the forking run. It may seem like forever, I've had it run for 4 to 5 days at times.
osity
Postby osity » 15.04.17, 17:50
Lol.... I let it run for a whole day and then decided it was a waste of time. I'll let it run for days instead.
Thanks for the message of hope !
Postby DataMedics » 15.04.17, 21:35
I'd still image it as far as you can first. Just in case the heads die during the process.
Filipp_TS
Postby Filipp_TS » 19.04.17, 13:39
Hi all!
Another way is recover translator manually - you can contact Technical support: http://ts.acelab.eu.com/
http://blog.acelab.eu.com/7-known-s ... cally.html
osity
Postby osity » 25.04.17, 15:45
Under section "what can i do if recover translator doesnt work" it says: "2. Try tiny Non-resident G-list adjusting or at least remove manually all defects with all non-zero flags."
Were is “tiny Non-resident G-list adjusting”?
osity
Postby osity » 25.04.17, 20:51
Filipp_TS wrote:Source of the post Hi all!
I just renewed my TS contract to get help with Filipp's "recover translator manually" method mentioned above as I didn't want to wait weeks for forking. Filipp just did exactly what I had done and told me to wait however many days it takes..... :shock:
Postby DataMedics » 26.04.17, 16:10
osity wrote:Source of the post
And, I'm pretty sure I told you that a week ago too. Had you listened, it'd be done already. :lol:
osity
Postby osity » 26.04.17, 16:35
:P Data medics, It had ran for 3 days and it hadn't moved! This time around I started it at the last readable sector rather than the first sector so that should save a few days off the month I will likely have to wait!
Postby DataMedics » 26.04.17, 20:44
In my experience it usually gets stuck in an area for a while and seems like it's not getting anywhere counting away one sector at a time. Then all of the sudden when you haven't been watching it a few days later, it's done.
osity
Postby osity » 26.04.17, 21:38
Well that certainly sounds like a nice scenario.
Postby DataMedics » 27.04.17, 21:43
Don't worry, these don't come up often at all. I've only had to do this twice I think. The first time I almost gave up thinking it would never finish. The second time I got smart and started it right be for leaving for a four day weekend.
osity
Postby osity » 27.04.17, 22:54
lol... apparently it was memorable.
osity
Postby osity » 28.04.17, 00:11
I'm hoping I don't need the USB Terminal connected for this.... I need it on the other channel for other jobs.
Postby Amarbir[CDR-Labs] » 28.04.17, 09:27
Hi Both Of You ,
One Observation i have had is that if one of the multiple heads are bad never do this as it senses all wrong info . I quick head swap and we are done
