I see this from the DE RAID manual:
300ddr wrote:Source of the post I thought it was possible to add drives to RAID from other ports on PC3K. That is: make a new task, then go to Explorer, "Add drive," and select any drive from SATA0 - SATA3. However, I don't see any of the other 3 drives I have connected. Any ideas?
300ddr wrote:Source of the post I KNEW that as soon as I sent that, I'd figure it out! Solution: start app so that it prompts desired SATA port (we use shortcuts, so didn't see this normally) then check the ports you want to access within 1 process.
Amarbir[CDR-Labs] wrote:Source of the post I have been using this since day one i got pc3k
Dmitriy_TS wrote:Source of the postAmarbir[CDR-Labs] wrote:Source of the post I have been using this since day one i got pc3k
Dear Amarbir, thank you for your feedback
300ddr wrote:Source of the post I think there is no reason to NOT use separate processes EXCEPT for RAIDs. If you use separate processes, and one crashes, only that one project/process will be closed. If, Amarbir, you are just using one process and one crashes, you lose everything that is currently running.
But, I was a bit disappointed to realize that you can only target/image one drive at a time after making RAID submap of files. I would love to be able to simultaneously clone the sectors required, on all drives, within the one process (and using different settings for each drive).
Return to “Data Extractor RAID Edition”
