Soldering of SATA Connector
lka124
Postby lka124 » 20.04.17, 08:08
Can someone help me to determine the capacitors, wich are to solder and the contacts for the SATA-Connector (E71, E72, E73, E75 are right?)?
LarrySabo
Re: Soldering of SATA Connector
Postby LarrySabo » 20.04.17, 14:06
lka124
Postby lka124 » 20.04.17, 14:25
Thanks so much, I was not sure.
Postby Amarbir[CDR-Labs] » 25.04.17, 05:30
ika124 ,
Were are you from ,Can you tell me this might be i can conduct a small class online on my Facebook for you to understand this concept properly ,But i suggest you swap to a data board as you will have the ability to switch on and off the drive specially if you do not have the USB power connecter acelab has released now
lka124
Postby lka124 » 25.04.17, 05:41
Hi Amarbir,
i'm from Germany, near Berlin. I have the USB power connector. I've also solder the capacitors, but I can not find a wire that fits in these holes :oops:
Postby Amarbir[CDR-Labs] » 25.04.17, 13:43
Please Connect to me on my facebook and send me a message ,I will then take a special class for you and explain you this my German friend
Return to “WD USB”
