What would cause the drive to be able to read sectors using "sector edit" in the utility but not in DE?
In DE I just get readiness loss error.
ST1000LM024 can read in sector edit but not DE
Moderator: Garry_TS
Re: ST1000LM024 can read in sector edit but not DE
Osity ,
Try To Set ector Read To 1 In DE In Your Case With Lower Read Speeds
Amarbir,
If you mean block size. I've tried that with no luck. I've also tried read timeouts as low as 60ms
osity wrote:Source of the post Amarbir,
Kindly disable head map in DE and then try might be it works also try pio mode " hardware tries " .Very Unique Problem BTW .
I've tried PIO as well. Do you mean disable all heads in DE? Not sure how that would work,
osity wrote:Source of the post I've tried PIO as well. Do you mean disable all heads in DE? Not sure how that would work,
Read What i Said "I am Saying Do Not Create a Head Map " Just Try Like This and If You Have Created Head Map Deselect That Not Deselect Heads
what does "If You Have Created Head Map Deselect That Not Deselect Heads" mean?
How would you disable the headmap after creating it without creating a new task?
