Which family I should choose for toshiba hdkpc09a0a01, or t01aca200
oldman
Postby oldman » 26.12.15, 22:18
2TB drive
Thanks.
Phil
oldman
Re: Which family I should choose for toshiba hdkpc09a0a01, or t01aca200
Postby oldman » 26.12.15, 22:19
The PCB was burnt, also the NVRAM chip. I have donor drive with same model.
Computek
Postby Computek » 31.03.17, 18:47
I know this is an old thread..
I have one of these drives which is parking heads..I'm suspecting its the control board but haven't been able to load the drive yet (PC 3000-E)
Noticed that people were having success with the hitachi 7210 module to load the drive - I tried it last night but no luck.. Just wondering if anyone has a way to load teh drive or knows which module to use thanks..
Postby Amarbir[CDR-Labs] » 02.04.17, 08:28
Computek wrote:Source of the post I know this is an old thread..
Please show a picture of the top label of the drive once
Computek
Postby Computek » 02.04.17, 15:22
Hi thankx for the reply... please see attached
Postby DataMedics » 02.04.17, 19:44
It's 7210DLE6 ARM Utility, however sometimes with this model you need to try loading a wrong utility first before it'll accept the tech key. You can see a video of how to load the utility for this one on this thread: https://www.data-medics.com/forum/hitac ... t1280.html
Blizzard
Postby Blizzard » 03.04.17, 00:05
DataMedics wrote:Source of the post It's 7210DLE6 ARM Utility, however sometimes with this model you need to try loading a wrong utility first before it'll accept the tech key. You can see a video of how to load the utility for this one on this thread: https://www.data-medics.com/forum/hitac ... t1280.html
I have had to do this a few times, luckily I had seen Jared's video in the past. Thanks Jared!
Postby Amarbir[CDR-Labs] » 03.04.17, 09:29
Hello Jared and Blizzard ,
You Do Not Need To Select Wrong Utility Just Select Tech Mode Detection :D ,Try It For a Change BTW :)
PS : Also Untick PCB Mode
Computek
Postby Computek » 03.04.17, 11:06
Great stuff .. thanks guys..will try it this evening when shop closes and see how we get on.. will give a report back as to success [or not] for others who may look for info in the future
much appreciated..
Blizzard
Postby Blizzard » 03.04.17, 15:14
Amarbir[CDR-Labs] wrote:Source of the post Hello Jared and Blizzard ,
Thanks Amarbir, I just tested a 3TB DT01ACA300, it appears that you just need to uncheck PCB mode, I didn't need to select tech key detection. If you look at Jared's video again you see that selecting the wrong model and running the utility unticks PCB mode.
I'll let you know if I see any issues with other models.
Postby DataMedics » 04.04.17, 14:18
That doesn't always work, I"ve documented this anomaly a few times. It's like it's using a tech key from a different family or something so loading the wrong one sometimes is the magic bullet.
Postby Amarbir[CDR-Labs] » 04.04.17, 15:38
Thanks Guys ,
Idea Is To Get The Job Done By Hook Or By Crook :P
Computek
Postby Computek » 10.04.17, 16:11
Well tried a that module with no luck. Also tried using incorrect module without any success. Drive is still clicking away. have tried connecting via com port and via drive initilization... keep getting a tech mode error or redynes time error ...
I'm strongly convinced this drive is having a pcb issue as opposed to physical heads issue...
will dig teh log/s out and post them when I get time...
Postby DataMedics » 11.04.17, 13:34
If the drive is clicking, then you're wasting your time trying to load the utility. You have to address the hardware issue before PC-3000 can even do anything.
Users browsing this forum: No registered users and 2 guests
