get ID correctly, cam read all modules and sys files without any problem. BUT can't access user area !!
here is the log:
(P) SATA Reset
RAW OFF
(DOS) Debug enabled
Intel 6G->3G
Send Status: COMRESET seen PASS
TotalSuperBlks 00069DF6 TotalValidSuperBlks 00069DED
on the RESET :
(P) SATA Reset
RAW OFF
(DOS) Debug enabled
Intel 6G->3G
Send Status: Phy Ready without COMRESET, Status=50 PASS
TotalSuperBlks 00069DF6 TotalValidSuperBlks 00069DEDj
Head resistance seems to be fine:
F3 T>/7
F3 7>X
Head 00 Resistance 021A
Head 01 Resistance 022F
F3 7>
Ctrl X Log:
F3 T>
ATA 15 Cmds
Ts(ms) dT(ms) Op Cnt LBA
0 99999999 00 0000 000000000000
0 0 00 0000 000000000000
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
2468 99999999 9 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000542D L 00000004 BO 000000 BES 009B900.009B9FF.009B900
2477 9 5 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000006933 L 00000001 BO 000000 BES 007184C.007188B.007184C
2483 6 10 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000B206 L 00000014 BO 000000 BES 00E1AC0.01DFFFF.00E1AC0
2505 22 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000006934 L 00000001 BO 000000 BES 007178C.00717CB.007178C
2517 12 2 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000AFF5 L 00000001 BO 000000 BES 009B900.009BCFF.009B900
2519 2 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000AFF5 L 00000001 BO 000000 BES 009B900.009B93F.009B900
2530 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000036551 L 00000001 BO 000000 BES 009B900.009B93F.009B900
2542 12 7 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000004A8B L 00000001 BO 000000 BES 009B900.009B93F.009B900
2549 7 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000004A8B L 00000001 BO 000000 BES 009B900.009B93F.009B900
2560 11 5 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000542D L 00000004 BO 000000 BES 009B900.009B9FF.009B900
2566 6 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000542D L 00000010 BO 000000 BES 009B900.009BCFF.009B900
2577 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000030989 L 00000010 BO 000000 BES 009B900.009BCFF.009B900
2588 11 9 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000B002 L 00000002 BO 000000 BES 009B900.009BCFF.009B900
2597 9 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000B002 L 00000002 BO 000000 BES 009B900.009B97F.009B900
2608 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000003655E L 00000002 BO 000000 BES 009B900.009B97F.009B900
2619 11 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000B002 L 00000002 BO 000000 BES 009B900.009BCFF.009B900
2630 11 5 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000004977 L 00000001 BO 000000 BES 009CCC0.009CCFF.009CCC0
2635 5 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000002FED3 L 00000001 BO 000000 BES 009CCC0.009CCFF.009CCC0
2646 11 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000005540 L 00000008 BO 000000 BES 009B900.009BCFF.009B900
2657 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000005540 L 00000008 BO 000000 BES 009B900.009BAFF.009B900
2668 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000030A9C L 00000008 BO 000000 BES 009B900.009BAFF.009B900
2679 11 3 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000006933 L 00000001 BO 000000 BES 007184C.007188B.007184C
2682 3 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000031E8F L 00000001 BO 000000 BES 007184C.007188B.007184C
2694 12 4 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000542D L 00000004 BO 000000 BES 009B900.009B9FF.009B900
2699 5 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000542D L 00000010 BO 000000 BES 009B900.009BCFF.009B900
2710 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000030989 L 00000010 BO 000000 BES 009B900.009BCFF.009B900
2721 11 14 02 008901 000000 1 00000080 XFR RD SYS LBA B 0000000258B2 L 00000088 BO 000000 BES 00D01EC.00D23EB.00D01EC
2736 15 28 02 008901 000000 1 00000080 XFR RD SYS LBA B 0000000268DA L 00000968 BO 000000 BES 00A9F00.00CF8FF.00A9F00
2782 46 8 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000493D L 00000008 BO 000000 BES 0071B8C.0071D8B.0071B8C
2790 8 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000002FE99 L 00000008 BO 000000 BES 0071B8C.0071D8B.0071B8C
3731 941 80 38 014101 000000 1 00000080 PWR Mode 101
11941 8210 190 38 014101 000000 1 00000080 PWR Mode 102
when try to read any sector:
Starting LBA of RW Request=00000100 Length=FFFFFFFF
ProcessRWError -Read- at LBA 00000100 Sense Code=43110081
SP is invalid
Unrecoverable Error Reported
So far I have tried a donor pcb, Translation Regeneration, s.m.a.r.t clear, disable media cache etc with no luck.
Translator recovery did't work on it.
will highly appreciate any help.
regards
