Rather than post the same thing twice, I figured I could just link to the post on my forum where I posted about a weird, but successful SSHD recovery we are just finishing up now.
ST1000LM014 SSHD Recovery
ST1000LM014 SSHD
Re: ST1000LM014 SSHD
Good job,
If you do it properly you should get full access to everything running at full speeds. In reality this model takes 5 minutes to solve if you know how to do it. plenty of tips on this forum.
Orldata wrote:Source of the post
Care to share?
I too have one of these sitting on the shelf and would be grateful for any info share. The weird thing with the one that I have is that it never spins. I tried a different PCB and still no spin, maybe the motors bad but I wanted to through it out to see if yours (lcoughey) did the same thing. Thanks
gterry wrote:Source of the post I too have one of these sitting on the shelf and would be grateful for any info share. The weird thing with the one that I have is that it never spins. I tried a different PCB and still no spin, maybe the motors bad but I wanted to through it out to see if yours (lcoughey) did the same thing. Thanks
Try my method and see if you have LBA access via utility.
I tried your method but the drive never comes RDY to continue. It sat for 45 minutes at BSY and remained there.
Just did a couple more cases this week and my process definitely works. The key is that you must hit CTRL-Z in terminal and it is only after you see the Request spin message will the drive eventually come ready.
