Create submap of previous map?
rogaland
Postby rogaland » 31.01.17, 09:07
Is it possible to create a map of used areas, and then limit this map based on legend? (to only try used, but skipped sectors for example) (for example?)
If so, how do I make sure that the map based on legend takes into account the "used areas" map, and doesn't include ALL skipped sectors on drive?
Nick_TS
Re: Create submap of previous map?
Postby Nick_TS » 31.01.17, 11:05
Yes you can do it. You can create map of used space (save it) then create submap using legend (and save it).
To be sure that map of used space contains map of skipped sectors you can make intersticktion of these two maps, result map should be equal map of skipped sectos.
rogaland
Postby rogaland » 31.01.17, 14:58
Thank you very much. Searching for "intersect" in the manual did not seem to return any documentation on how to create this intersection between the two saved maps, but I guess I'll figure it out?
Postby Amarbir[CDR-Labs] » 21.02.17, 06:30
rogaland wrote:Source of the post Thank you very much. Searching for "intersect" in the manual did not seem to return any documentation on how to create this intersection between the two saved maps, but I guess I'll figure it out?
Here,
read and understand -> http://blog.acelab.eu.com/operation ... itmap.html
rogaland
Postby rogaland » 22.02.17, 08:53
Thank you! Now I'll be able to use DE more efficiently!
Return to “Data Extractor”
