What I did is a surface test, remove interactions and intersection, add defects into P-list and regenerate translator.
After turning off the hard disk and re-run the utility I do another surface test and I get the same defects, it's seems to me that anything is changed into P-list.
What is the correct procedure to add defects into P-list?
Thanks in advance
