I think I just encountered my first fusion drive, from a 27" iMac.
I only have the 3TB DM001 seagate that's suffering from the regular problems, yet is still mostly clone-able.
To add to the fun, filevault2 is also being used.
I wasn't able to decrypt the data on the fly with just the 3TB Seagate, since I couldn't find the EncryptedRoot.plist.wipekey file on the 3TB drive in the location below. I assume it's on the 128GB SSD. Can anyone confirm they've found it on the SSD? (again, I don't have the 128GB SSD yet).
A quick google search shows: The key file is EncryptedRoot.plist.wipekey found in com.apple.boot.X /System/Library/Caches/com.apple.corestorage/ (where X can change among literals R, S and P).
In my case, I was able to create a 99.96% perfect clone of the 3TB drive. Unfortunately though, it doesn't detect on a Mac, or ask for a password like it normally would, I assume since apparently the SSD is combined/added to the 3TB, and doesn't behave like cache.
My plan is to acquire and clone the 128GB SSD and try plugging that into a Mac with the 3TB clone and see what happens.
I just thought I'd ask if anyone had confirmation that this might work or had other suggestions from experience with these.
Without the 128GB SSD, it seems I might be missing a key piece to the puzzle.
I also wonder if DE is able to decrypt on the fly from these drives if both the SSD and hard drive are both present.
iMac's Fusion Drive 128GB SSD + ST3000DM001
Re: iMac's Fusion Drive 128GB SSD + ST3000DM001
This should work and I believe there is no other option. That is: you need both drives from the "fusion drive" to recover any data.
It seems like the SSD might have been formatted prior to me receiving it...Should I be seeing data / an encrypted partition on the SSD, or would it look like a blank/formatted drive (like mine does)?
I'd expect it to be full of data, or at least something in the very beginning. If all zeros, I'd guess either formatted or wrong drive.
