any soluation??
in terminal:
II Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>[0000000000000000]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
FAILED to spare00000903
Device Fault is set!
ClearMC: Completed, Last LBA 0000440408
MCInitialize: MC Cleared
MCInitialize: MCTBufferPtr->Header.MCTStateFlags = 0000000A
MCInitialize: MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCInitialize: MCStateFlags = 00000001
Set MCMT Version Current
[MCMTWS] Tail/Head 0000 0000
MCInitialize: Init complete:
MCMainPOR: MCTStateFlags 00000022 MCStateFlags 00000041 Tms 0000098A
ASCII Diag mode
F3 T> PASS
SP200: MSPMainPOR Start
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
Starting LBA of RW Request=0000000000 Length=000001BC
ProcessRWError -Read- at LBA 0000000000 Sense Code=43110081
ASCII Diag mode
F3 T>
ERC TO exceeded, orig value in us:FFFFFFFF
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000000
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000000
MSP Reconstruction: EXCEPTION: Read MSP Segment Error
Segment 0000 StartLBA 00000000 ErrorLBA 00000000
Error in MSP Header
Continue MSP Read, PreError Segment Cnt0000
Num Segments 006F
ASCII Diag mode
ProcessRWError -Write- at LBA 0000000000 Sense Code=C4090081
ASCII Diag mode
ASCII Diag mode
F3 T>
FAILED to spare00004903
MSP ERROR: Init ScratchPad Disc
MSP MainPOR: 00003000 Tms 0000098A 00000CB5 00001718
MSP ERROR: ScratchPad disabled
No HOST FIS-ReadyStatusFlags 0002A181
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22
SIM Error 2012 LBA 000000000008EC37 FD FC35401D
RW Error 00000080
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 00000080, File Error 00000000
seagate st3000dm001
Re: seagate st3000dm001
So you tried to regenerate translator without even checking NRG??? That's living dangerously.
The issue is 100X more likely related to the media cache than the translator. Hopefully, you didn't botch the recovery now by doing something you didn't understand.
Simple ,
Disable Media Cache in this drive
DataMedics wrote:Source of the post So you tried to regenerate translator without even checking NRG??? That's living dangerously.
Are you recommending backing up 35 before any translator work?
I backup everything before translator work. And I always check for NRG first or it's going to go sideways on you.
I backup everything also if the drive co-operates through ATA.
What do you back up through terminal when you can get ATA access?
If terminal is only option, I've been backing up:
1BH P-list
28H Translator
35H NRG
93H HDD ID
I forget which module ROM is, but I get that one too. I would imagine i might be missing some important ones....
1BH P-list
28H Translator
35H NRG
93H HDD ID
