Samsung MZ-VKV512 950 Pro
oldman
Postby oldman » 03.12.16, 19:51
Just hope that someone got idea for this SSD drive, it is detected, just can not access the data area. Look some firmware problem, but pc-3000 does not support it.
Thanks.
Phil
Re: Samsung MZ-VKV512 950 Pro
Postby Amarbir[CDR-Labs] » 11.12.16, 06:29
oldman wrote:Source of the post Just hope that someone got idea for this SSD drive, it is detected, just can not access the data area. Look some firmware problem, but pc-3000 does not support it.
Thanks.
Phil
Hello Phil ,
Roman would be the guy to ask for this ,you could also post in flash section of hddguru and see if a expert could help you
Postby Roman_TS » 14.12.16, 11:46
Hi all!
950 Pro will appear in support list in 2017 I suppose.
oldman
Postby oldman » 04.01.17, 01:03
Hi Roman and Amarbir,
Thanks for your reply.
Does Samsung 950 Pro has the same problem as 850, with encrypted terminal?
Wonder why ACE lab does not provide me the M2 Key M adapter, I ordered and only received the Key B, or key B+M adapter, are there any ways to read the Key M?
Thanks.
Phil
Return to “Other SSD Samsung”
