has anyone tested what is terminal connection scheme for this drive ?
PCB is: 2060-771859
thanks in advance.
wd5000lmvw-11ckrs0 terminal connection
- GuideRecovery
- New user
Wasim Zafar
https://mindmergepk.com
Wasim Zafar
- GuideRecovery
- New user
Re: wd5000lmvw-11ckrs0 terminal connection
anyone has any clue ?
Wasim Zafar
Wasim Zafar
It works fine with the WD terminal adapter.
- GuideRecovery
- New user
my bad, dont have WD terminal adapter, still using Toshiba.
Its time to get those new terminals.
thanks for pointing out.
Wasim Zafar
Wasim Zafar
- GuideRecovery
- New user
today i got comaptible SATA pcb for this drive, ROM chip on SATA PCB is different in shape and in size (512KB) whereas the ROM of patient is 256KB.
my question is is it safe to write the patient rom after pading zeros at the end of it and make size 512KB ?? has anyone tested it ?
USB PCB IS: 2060-771859-000
SATA PCB : 2060-771852-004
or i should simply move ROM chip to donor SATA PCB.
thanks
thanks
Wasim Zafar
Wasim Zafar
- GuideRecovery
- New user
Jrrrrrrrrrrr.. samsung terminal adapter work just fine.
BAM...
BAM...
Wasim Zafar
Wasim Zafar
