Large areas of FF pattern
gterry
Postby gterry » 17.10.16, 18:50
What does it mean when there are large areas of FF in reading the data in hex? Is that something left over from a full format or is there a significance to the FF pattern?
Re: Large areas of FF pattern
Postby DataMedics » 17.10.16, 20:20
It could be that the bits are inverted. 00 when inverted appears as FF, so that could be the blank space.
Postby Roman_TS » 18.10.16, 09:05
FF might means empty place. Ask your customer - how much data on his flash drive that you are going to recover :)
gterry
Postby gterry » 18.10.16, 14:30
Thanks guys, I thought the same just wanted another opinion :D
