who can help me to solve this Password Problem??
WD USB Decryption is Password protected ...HELP
Re: WD USB Decryption is Password protected ...HELP
Easy...ask the client for the password.
If client forgot password?
never set any Password...
Are you able to fully clone the drive without read errors?
lcoughey wrote:Source of the post Are you able to fully clone the drive without read errors?
Sir ,
Assuming He Is What Is Your answer Then And Assuming It Isn'nt Then Whats The Answer
Amarbir[CDR-Labs] wrote:Source of the postlcoughey wrote:Source of the post Are you able to fully clone the drive without read errors?
Sir ,
I think what Luke's suggesting is that the key sector near the end might not have been read properly. I've had at least one case where that sector was bad.
DataMedics wrote:Source of the postAmarbir[CDR-Labs] wrote:Source of the postlcoughey wrote:Source of the post Are you able to fully clone the drive without read errors?
Sir ,
Might Be Can Reverse Clone Some Portion of Patient
goooz, try to solve the Slow Responding, then connect the original USB PCB. If it also requires the password, it's the bug of INIC1607E and it can not be solved.
Such bug puts some LBA from user area to key module.
Maxim_TS wrote:Source of the post goooz, try to solve the Slow Responding, then connect the original USB PCB. If it also requires the password, it's the bug of INIC1607E and it can not be solved.
Dear Maxim, i have to disagree with you here, but IT IS POSSIBLE and CAN BE SOLVED.
Thank you
Dear einstein9, I've heard about the donor modules for such cases, but never tried this method since I have no such cases here last month.
As soon I try it, I will let you know.
