I have this hard disk for data recovery.
The drive had a dropped and after that able to accses user data but read very slow (10-30kb/s)
But i manage to copy out the hdd resources (rom and module)
so i try to do the solve slow responding problem.
http://blog.acelab.eu.com/pc-3000-h ... oblem.html
at step No. 2 i notice my WD 2.5" 2TB drive should have 8 heads,
but my PC3000 screen shows only 2 rows of address.
at step no. 5 , my log has an error :
Techno mode key
RAM:
ROM:
Modules directory address............... : 318 137
SA regions address...................... : shifted
ROM Modules:
ROM version............................. : 21.2CH
ROM F/W version......................... : 0021002C
Overlay F/W version..................... : 21.2CH
Servo F/W version....................... : N0.38
Heads number in use..................... : 8
Heads map............................... : 0,1,2,3,4,5,6,7
Module (0011) read error Module ID 11 reading error Data request error - Drive is not ready
after which, the drive ID become not able to auto detect.
I changed a new head into the drive.( the head has a known head 0 can read cannot write, head 1 can read/write)
I'm still getting the same error.
I try to load the modules from the previously backup from this drive, i cannot access the drive.
If I load ldr 11.rpm as permanent overlay from a downloaded resource from hddguru website, i can read the front few user sector.
if i jump to final sector, the drive will become busy forever.
if i go to data extraction. The drive will reinitialise and my drive become unable to detect.
My modules also have problem :
Modules checking
Module 01............................... : Ok
Module 35............................... : Ok
Module 12E.............................. : Ok
Module 102.............................. : Ok
Module 103.............................. : Ok
Module 104.............................. : Ok
Module 105.............................. : Ok
Module 106.............................. : Ok
Module 108.............................. : Ok
Module 02............................... : Ok
Module 1B............................... : Ok
Module 411.............................. : Ok
Module 2F............................... : Ok
Module 2A............................... : Ok
Module 21............................... : Ok
Module 23............................... : Ok
Module 24............................... : Ok
Module 11............................... : Module reading error: ABA 320 028(1) reading error - Device Error Detected: "Unknown error code: 51AD"
Module 50............................... : Ok
Module 51............................... : Ok
Module 52............................... : Ok
Module 53............................... : Ok
Module 109.............................. : Ok
Module 6E............................... : Ok
Drive is not ready
Module 116.............................. : Module reading error: ABA 13 884(1) reading error - Drive is not ready
Drive is not ready
Drive is not ready
Module 118.............................. : Module reading error: ABA 13 890(1) reading error - Drive is not ready
Drive is not ready
Drive is not ready
Module AC55............................. : Module reading error: ABA 321 113(1) reading error - Drive is not ready
Drive is not ready
Drive is not ready
Module 4002............................. : Module reading error: ABA 321 114(1) reading error - Drive is not ready
Drive is not ready
Drive is not ready
Module 6D............................... : Module reading error: ABA 321 115(1) reading error - Drive is not ready
Drive is not ready
Drive is not ready
Module 122.............................. : Module reading error: ABA 321 116(1) reading error - Drive is not ready
Drive is not ready
Anyone can help on this?
