Dear Friends
This disk is showing typical error of P list corruption. Is someone having modules for this model ?
Thank you
Need Modules for MHY2160BH
Re: Need Modules for MHY2160BH
Athena wrote:Source of the post Dear Friends
Thank you
plist is unique to every hard drive its not replaceable from other donors
Amarbir[CDR-Labs] wrote:Source of the postAthena wrote:Source of the post Dear Friends
Thank you
HI Amarbirji
Thanks for replying.I mean actual P list is not corrupt. Its like this --
even if some modules are corrupt , zone allocation reading fails so its not actual P list corruption.
These are A or B modules if they are repaired sector access becomes normal.I can read P list perfectly .
Here is log --
elected family......................... : MHW2xxxBH
Selected model.......................... : MHWxxxxBH
Model by HDD ID......................... : FUJITSU MHW2160BH PL
Firewall state: 0
Unlocking...
Firewall state: 2
Tech command set: SATA cmd set
Reading module table from SA...
Module table is loaded
Loading : HS, head map module......................................... : Ok
Loading : PL, single sector defect list and zone allocation table module : Error
Error................................................................. : PL: Invalid zones distribution info (ZoneNo)!
LOADING MODULES
Module 10004.......................................................... : Ok
Module 10020.......................................................... : Ok
Module 10006.......................................................... : Ok
Module 10022.......................................................... : Ok
Module 100E1.......................................................... : Ok
Can`t read module 1003D from HDD
Module 1003D.......................................................... : Error
Can`t read module 1003E from HDD
Module 1003E.......................................................... : Error
Can`t read module 1003F from HDD
Module 1003F.......................................................... : Error
Can`t read module 10040 from HDD
Module 10040.......................................................... : Error
Can`t read module 1005A from HDD
Module 1005A.......................................................... : Error
Can`t read module 1005B from HDD
Module 1005B.......................................................... : Error
Module 10001.......................................................... : Ok
Can`t read module 100E8 from HDD
Module 100E8.......................................................... : Error
Module 10007.......................................................... : Ok
Module 100E2.......................................................... : Ok
Module 10008.......................................................... : Ok
Can`t read module 1000C from HDD
Module 1000C.......................................................... : Error
Can`t read module 1000D from HDD
Module 1000D.......................................................... : Error
Module 1000A.......................................................... : Ok
Module 1002D.......................................................... : Ok
Module 1002B.......................................................... : Ok
Module 1002A.......................................................... : Ok
Module 10009.......................................................... : Ok
Module 10031.......................................................... : Ok
Module 10027.......................................................... : Ok
Module 10032.......................................................... : Ok
Module 10028.......................................................... : Ok
Module 10045.......................................................... : Ok
Module 10070.......................................................... : Ok
Module 10029.......................................................... : Ok
Module 10037.......................................................... : Ok
Module 100E9.......................................................... : Ok
Module 100EA.......................................................... : Ok
Can`t read module 100ED from HDD
Module 100ED.......................................................... : Error
Module 1006C.......................................................... : Ok
Can`t read module 10050 from HDD
Module 10050.......................................................... : Error
Can`t read module 10055 from HDD
Module 10055.......................................................... : Error
Can`t read module 10054 from HDD
Module 10054.......................................................... : Error
Module 10051.......................................................... : Ok
Module 10052.......................................................... : Ok
Can`t read module 10057 from HDD
Module 10057.......................................................... : Error
Can`t read module 10058 from HDD
Module 10058.......................................................... : Error
Module 10002.......................................................... : Ok
Module 1000B.......................................................... : Ok
Module 10005.......................................................... : Ok
Module 1000E.......................................................... : Ok
Module 10030.......................................................... : Ok
Module 10035.......................................................... : Ok
Module 10036.......................................................... : Ok
Module 1002E.......................................................... : Ok
Module 10041.......................................................... : Ok
Module 10042.......................................................... : Ok
Module 100A0.......................................................... : Ok
Module 10003.......................................................... : Ok
Module 100E3.......................................................... : Ok
Module 100A9.......................................................... : Ok
Module 100AA.......................................................... : Ok
Module 100AB.......................................................... : Ok
Module 100AC.......................................................... : Ok
Module 100AD.......................................................... : Ok
Module 10023.......................................................... :
Athena wrote:Source of the postAmarbir[CDR-Labs] wrote:Source of the postAthena wrote:Source of the post Dear Friends
Thank you
HI Amarbirji
Here is log --
Firewall state: 0
Unlocking...
Firewall state: 2
LOADING MODULES
Well Cannot Say anything to this statement you Made .I Am Not To Well Versed With Fujitsu Drives ,But i am Of the Opinion PC 3k Makes a Lot Of Errors in SA even in a OK Drive Wonder Why ,Try it With Some Other Tools also
Hi Fillip & Pavel .. TS team
PM sent are not getting delivered & are laying in outbox only.
Kindly look into the matter as it is causing great inconvinience.
Thank you
Thank you
Hi all
Yes, correct.
This message mean not an error of P-list.
It mean that drive have a special format of P-list and it can't be recognazable by utility.
Amarbir[CDR-Labs] wrote:Source of the post plist is unique to every hard drive its not replaceable from other donors
Yes, correct.
Athena wrote:Source of the post Loading : PL, single sector defect list and zone allocation table module : Error
