Dear
Seniors,
i have case Samsung spin point momentous ST1000LM024(2AR20003) drive was silent no movement only BSY i have tried replace same model donor PCB with replaced ROM then same no movement
after i have placed donor PCB with donor ROM spins good .
only original ROM not spins i have tried 2pcbs is it ROM damaged ?
Any solution...
Thanks & Regards
Pavan Kumar
CS DATA RECOVERY
Samsung Spin point ST1000LM024 NO MOVEMENT
Moderator: Garry_TS
- CS DATA RECOVERY
Regards,
PAVAN KUMAR
CS DATA RECOVERY
PAVAN KUMAR
CS DATA RECOVERY
Re: Samsung Spin point ST1000LM024 NO MOVEMENT
Hello Pavan,
What is a terminal log with original ROM?
Did you manage to get a solution to this.
