Hi everyone,
I've received my PC-3000 UDMA a couple of days ago. I've installed the board into one of the PCs here
Motherboard: ASROCK H97M Anniversary
Power Supply: SilverStone 700W Strider Essential
Both Channel & SATA cables connection
I've tried SATA-0 & Channel 0: Don't power on HDD that connected to PC-3000 (Power indicator on the lower right of the program are in red color)
I've tried SATA-1 & Channel 1: Same result
I've switched it to another PC: same result
I've tried to connect SATA 0 from the board to a HDD, power supply from PC - It works, it powered up HDD and everything looks just alright.
Can anyone tell me what is wrong with my setup?
Thanks in advance
Best Regards,
Darecom
PC-3000 Not Power up HDD
Re: PC-3000 Not Power up HDD
Is your PC-3000 board also connected to the power supply? Can be easily overlooked when installing the board.
I'm just waiting for the "DOH!" response to be posted.
Hi JayPiKay,
Yea it is. power supply from PC --> POWER IN
Maybe you have a bad power supply relay board on the PC-3000. I know I had one light on fire early on when I was using PC-3000. Never had an issue since it was replaced.
I'd probably break out a multimeter and check voltages on everything, make sure you've tried different HDD's connected to the channel, etc. to rule everything out before putting in a ticket with Ace.
