St932032As partial access on LBA
redlabs
Postby redlabs » 28.07.16, 11:33
Dear Frds ...
I have received 320 GB wyatt family F/w : 0002BSM1 , reading partially 0 - 300000000 LBA sector only total 298.09 GB (625 142 448) ..Please give me any solution for this case
redlabs
Re: St932032As partial access on LBA
Postby redlabs » 31.07.16, 07:16
Any one knows please update frds
Postby AJ2008 » 01.08.16, 09:44
What was original symptoms when you received this case?
redlabs
Postby redlabs » 01.08.16, 15:28
same reading problem friend ...
Postby AJ2008 » 01.08.16, 17:22
Can you post output from V40 here?
redlabs
Postby redlabs » 02.08.16, 07:52
Rst 0x08M
(P) SATA Reset
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>V40
Total entries available: 0
F3 T>
Thank you
Postby AJ2008 » 02.08.16, 10:24
NRG is empty and since you have partial translator loaded I assume NRG entries were cleared during some translator rebuild.
Did you try to run Recovery Translator option?
redlabs
Postby redlabs » 02.08.16, 11:20
YES I try to rebuild but same result finally ..
Postby AJ2008 » 02.08.16, 11:48
Did Translator Recovery option complete or did it give error about correcting manually?
redlabs
Postby redlabs » 02.08.16, 11:52
If i run translator ,Lots of UNC error is coming and not completed ,I have stop that translator recovery
Thank you frds ,please give me your suggestion
redlabs
Postby redlabs » 03.08.16, 07:21
hello frd
Please update ..
