We have changed PCB and Heads with suitable donor on this drive but can't get any access. ROM is readable but no crucial modules. Drive spins up and we can hear heads come out. Drive continues to spin. Comes ready quickly. Same symptoms with new heads and new pcb.
Selected family......................... : 5475A9
Model by ID............................. : <ID IS NOT READ>
Error startintg command: Reading SA [0x3F0000004, 0x4]
Device error detected (ABR)
Error startintg command: Reading SA [0x3F0000004, 0x1]
Error reading module USAG(0): Error startintg command: Reading SA [0x3F0000004, 0x1]
Error startintg command: Reading SA [0x3F0100004, 0x4]
Error startintg command: Reading SA [0x3F0100004, 0x1]
Error reading module USAG(1): Error startintg command: Reading SA [0x3F0100004, 0x1]
Error : .............................................................. : Module USAG: no copies read!
HTS547550A9E384 No SA access / No ID
Re: HTS547550A9E384 No SA access / No ID
Looks like this is problem directly with USAG module.
As result drive can't to recognize SA modules table.
Filipp_TS wrote:Source of the post Hello,
Hi Filipp,
Any solution to this?
zeroalpha wrote:Source of the postFilipp_TS wrote:Source of the post Hello,
Hi Filipp,
Hitachi drives haven't a something alternative reading mode (like HotSwap, Kernel etc) except original ATA mode.
That's why we can't to get SA access for checking SA modules and the only way is test drive with the donor parts from the donor Drive(s).
Try to set the donor PCB with the patient ROM and take a look on drive behavior.
Also you can check this drive inside and set the donor Heads.
Hi zeroalpha,
Did you get anywhere with this drive. Or does anyone have a solution. We have a HTS545050A7E362 with same symptom and have carried out the same rework with no success. I would appreciate any ideas.
Possible way has been provided in my previous message.
Unfortunately no other solutions.
I currently have a one of these in; same symptoms of failure. Drive sounds good, enters RDY quickly but just gives ABORT errors. USAG is not readable. Donor PCB and/or donor heads make no difference.
Has anyone come to a solution for this ? I presume not due to the limits of the Hitachi architecture.
Thanks,
J
Thanks,
J
Is there any updated solution for this issue? Thanks!
Trouse, if SA and NV-RAM are good, there is a way to initialize the patient using the resources from same FW donor drive described here: http://blog.acelab.eu.com/hitachi-i ... -mb-2.html
Maxim_TS wrote:Source of the post Trouse, if SA and NV-RAM are good, there is a way to initialize the patient using the resources from same FW donor drive described here: http://blog.acelab.eu.com/hitachi-i ... -mb-2.html
Maxim, I have a similar case, but I think the method described in the blog is useless if the patient cannot reach the SA and therefore read the most important modules and save them (as described in the article).
Users browsing this forum: Baidu [Spider] and 14 guests
