Samsung ST1000LM025 USB TO SATA
Moderator: Garry_TS
huangmiaofang
Postby huangmiaofang » 21.07.16, 12:40
Model ST1000LM025 PN:/HN-M101ABB/EXA
CPU :88I9422-NDB2
USB Chip: JMS577
PCB Info :100760718 rev.c
replace to sata
CPU:88I9422-NDB2
PCB info : 100720903 04 PCB label Rev.7
ST1000LM025
huangmiaofang
Re: Samsung ST1000LM025 USB TO SATA
Postby huangmiaofang » 21.07.16, 12:51
USB to sata control image
sata1 .jpg (83.82 KiB) Viewed 21204 times
Postby Amarbir[CDR-Labs] » 21.07.16, 17:12
What Kinda Post Is this Are You Explaining Us that you did this and sharing or you have a question
lcoughey
Postby lcoughey » 21.07.16, 18:50
It does make you wonder what the point of the post is, doesn't it? Perhaps they want to know which chip needs to be transplanted from the USB to make the SATA PCB compatible.
Postby Amarbir[CDR-Labs] » 21.07.16, 18:58
lcoughey wrote:Source of the post It does make you wonder what the point of the post is, doesn't it? Perhaps they want to know which chip needs to be transplanted from the USB to make the SATA PCB compatible.
Well Luke Sir ,
He did Not Ask For This Also Hence i Am Wondering
huangmiaofang
Postby huangmiaofang » 22.07.16, 01:41
hi,
I have no other meaning, just describe this 2 board is replaced, the problem has been resolved!
Return to “Samsung USB”
