DataMedics wrote:Source of the post Backup the SA first. Then I would try regenerate translator.
I tried make Backup the SA, But I get some error in log, I add the log to see it and give me your opnion
Code: Select all
Test : HDD resources backup
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Wyatt\ST9500325AS-0005HPM1-6VECVBMZ\Data\SABackup\
Reading ROM to profile folder
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Wyatt\ST9500325AS-0005HPM1-6VECVBMZ\Data\SABackup\ROM\
Reading DT to profile folder
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Wyatt\ST9500325AS-0005HPM1-6VECVBMZ\Data\SABackup\CPDir\
DT 0000 (Flash ROM), Read Adaptive Parameters File (RAP).............. : Ok
DT 0001 (Flash ROM), Controller Adaptive Parameters File (CAP)........ : Ok
DT 0004 (Flash ROM), Servo Adaptive Parameter File (SAP).............. : Ok
DT 0005 (Flash ROM), Servo Firmware Table............................. : Ok
DT 000A (Flash ROM), Seek Profile..................................... : Ok
DT 0013 (Flash ROM), Dependent Zone Table for User Area............... : Ok
DT 0014 (Flash ROM), Dependent Zone Table for System Area............. : Ok
DT 0015 (Flash ROM), Flash ROM........................................ : Ok
DT 001B (Flash ROM), Dependent Zone Group Tables for User Area........ : Ok
DT 001C (Flash ROM), Dependent Zone Group Tables for System Area...... : Ok
DT 001D (Flash ROM), VBAR Configuration File.......................... : Ok
DT 001E (Flash ROM), Zone Format Parameters File...................... : Ok
DT 0000 (RAM), Read Adaptive Parameters File (RAP).................... : Ok
DT 0001 (RAM), Controller Adaptive Parameters File (CAP).............. : Ok
DT 0002 (RAM), Zone Table............................................. : Ok
DT 0004 (RAM), Servo Adaptive Parameter File (SAP).................... : Ok
DT 0005 (RAM), Servo Firmware Table................................... : Ok
DT 0006 (RAM), Servo Flaw Table....................................... : Ok
DT 000A (RAM), Seek Profile........................................... : Ok
DT 0013 (RAM), Dependent Zone Table for User Area..................... : Ok
DT 0014 (RAM), Dependent Zone Table for System Area................... : Ok
DT 0015 (RAM), Flash ROM.............................................. : Ok
DT 0016 (RAM), Drive Configuration Table.............................. : Ok
DT 0017 (RAM), Temperature Control Configuration...................... : Ok
DT 001B (RAM), Dependent Zone Group Tables for User Area.............. : Ok
DT 001C (RAM), Dependent Zone Group Tables for System Area............ : Ok
DT 001D (RAM), VBAR Configuration File................................ : Ok
DT 001E (RAM), Zone Format Parameters File............................ : Ok
DT 001F (RAM), RW working user preamp table........................... : Ok
DT 0020 (RAM), RW working system preamp table......................... : Ok
DT reading process completed
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Wyatt\ST9500325AS-0005HPM1-6VECVBMZ\Data\SABackup\ModDir\
Will be skipped : 000C, 000E, 000F, 0022, 0023, 0024, 0025, 002C, 002D, 002E
Module 0001, Drive Information File (DIF)............................. : Ok
Module 0002, Performance Parameter File (PPF)......................... : Ok
Module 0003, Primary Defect File (P-List))............................ : Ok
Module 0004, Servo Adaptive Parameter File (SAP)...................... : Ok
Module 0005, Manufacturing Information File (MIF)..................... : Ok
Module 0006, Read Adaptive Parameters File (RAP)...................... : Ok
Module 0007, Controller Adaptive Parameters File (CAP)................ : Ok
Module 0008........................................................... : Ok
Module 0009, SMART Configuration File................................. : Ok
Module 000A, SMART Data File.......................................... : Ok
Module 000B........................................................... : Ok
Module 000D........................................................... : Ok
Module 0013, Disc Registry File (settings, security, etc)............. : Ok
Module 0015, BGMS File (Directed Offline Scan)........................ : Ok
Module 0016........................................................... : Ok
Module 0017........................................................... : Ok
Module 0019, Log File................................................. : Ok
Module 001A, Log File................................................. : Ok
Module 001B, Log File................................................. : Ok
Module 001C........................................................... : Ok
Module 001D, Physical Overlay File 0.................................. : Ok
Module 001E, Physical Overlay File 1.................................. : Ok
Module 001F, Physical Overlay File 2.................................. : Ok
Module 002A, Saved Mode Pages (HDD settings).......................... : Ok
Module 002B, R/W Operating Parameters (translator, etc)............... : Ok
Module 0033........................................................... : Ok
Module 0034, Packed CONGEN XML definition............................. : Ok
Module 0035, SMART Data............................................... : Ok
Reading HDD ID pages list...
Reading HDD ID pages...
ID Page 00............................................................ : Ok
ID Page 01............................................................ : Ok
ID Page 02............................................................ : Ok
ID Page 03............................................................ : Ok
ID Page 04............................................................ : Ok
ID Page 08............................................................ : Ok
ID Page 09............................................................ : Ok
ID Page 0A............................................................ : Ok
ID Page 0B............................................................ : Ok
ID Page 0C............................................................ : Ok
ID Page 0D............................................................ : Ok
ID Page 0E............................................................ : Ok
ID Page 0F............................................................ : Ok
Reading System Files to profile folder
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Wyatt\ST9500325AS-0005HPM1-6VECVBMZ\Data\SABackup\SysFiles\
Copies : 0 1
Sys File FC000000(0).................................................. : Error
Error : Rq Rd Sys File part ID 0, Offs 0x0 err! Tech state 0x72, 0x04440000
Sys File FC000000(1).................................................. : Ok
Sys File FC001203(0).................................................. : Error
Sys File FC001203(1).................................................. : Ok
Sys File FC002204(0).................................................. : Error
Sys File FC002204(1).................................................. : Ok
Sys File FC003205(0).................................................. : Error
Sys File FC003205(1).................................................. : Ok
Sys File FC004206(0).................................................. : Error
Sys File FC004206(1).................................................. : Ok
Sys File FC00520B(0).................................................. : Error
Sys File FC00520B(1).................................................. : Ok
Sys File FC00620C(0).................................................. : Error
Sys File FC00620C(1).................................................. : Ok
Sys File FC00720D(0).................................................. : Error
Sys File FC00720D(1).................................................. : Ok
Sys File FC345010(0), Primary Defect File (P-List))................... : Error
Sys File FC345010(1), Primary Defect File (P-List))................... : Ok
Sys File FC34D01C(0), R/W Operating Parameters (translator, etc)...... : Error
Sys File FC34D01C(1), R/W Operating Parameters (translator, etc)...... : Ok
Sys File FC34F026(0).................................................. : Error
Sys File FC34F026(1).................................................. : Ok
Sys File FC353100(0), Physical Overlay File 0......................... : Error
Sys File FC353100(1), Physical Overlay File 0......................... : Ok
Sys File FC354101(0), Physical Overlay File 1......................... : Error
Sys File FC354101(1), Physical Overlay File 1......................... : Ok
Sys File FC355102(0), Physical Overlay File 2......................... : Error
Sys File FC355102(1), Physical Overlay File 2......................... : Ok
Sys File FC356103(0).................................................. : Error
Sys File FC356103(1).................................................. : Ok
Sys File FC357104(0).................................................. : Error
Sys File FC357104(1).................................................. : Ok
Sys File FC358105(0).................................................. : Error
Sys File FC358105(1).................................................. : Ok
Sys File FC359106(0).................................................. : Error
Sys File FC359106(1).................................................. : Ok
Sys File FC35A107(0).................................................. : Error
Sys File FC35A107(1).................................................. : Ok
Sys File FC35B108(0).................................................. : Error
Sys File FC35B108(1).................................................. : Ok
Sys File FC35C109(0).................................................. : Error
Sys File FC35C109(1).................................................. : Ok
Sys File FC35D10A(0).................................................. : Error
Sys File FC35D10A(1).................................................. : Ok
Sys File FC35E10B(0).................................................. : Error
Sys File FC35E10B(1).................................................. : Ok
Sys File FC35F10C(0).................................................. : Error
Sys File FC35F10C(1).................................................. : Ok
Sys File FC36010D(0).................................................. : Error
Sys File FC36010D(1).................................................. : Ok
Sys File FC361110(0).................................................. : Error
Sys File FC361110(1).................................................. : Ok
System Files reading process completed
Reading loader data to folder (LDR)
Scanning LOD files...
reading file FC00620C...
reading file FC353100...
Appending: Overlay ID = 00
reading file FC354101...
Appending: Overlay ID = 01
reading file FC355102...
reading file FC356103...
Appending: Overlay ID = 04
reading file FC357104...
Appending: Overlay ID = 05
reading file FC358105...
reading file FC359106...
reading file FC35A107...
reading file FC35B108...
reading file FC35C109...
reading file FC35D10A...
reading file FC35E10B...
reading file FC35F10C...
reading file FC36010D...
and in every error it make SATA Reset in terminal mode
Send Status: COMRESET seen
(S) SATA Reset
I didn't make regenerate translator, becouse Im a fraid to make nagative effect to HDD , So Im waitting your reply,,
