WD10EACS-00ZJB0 ROM 005C0032 Required
odedshankar
Postby odedshankar » 18.07.16, 08:51
Hi Folks does anyone have this firmware: WD10EACS-00ZJB0 ROM 005C0032
or even just the 11.RPM loader will help a lot.
Re: WD10EACS-00ZJB0 ROM 005C0032 Required
Postby AJ2008 » 18.07.16, 09:31
Im pretty sure these have internal ROM, cant you ROM build using a donor PCB?
Alternatively you can use donor PCB and LDR from the same donor to reach SA and make ROM manually from modules in SA
Postby DataMedics » 18.07.16, 19:22
I think he's looking for the LDR, he was just pointing out the ROM version. The title threw me off too.
Anyway, here you go:
005C0032.rar
(157.3 KiB) Downloaded 371 times
Postby AJ2008 » 19.07.16, 16:48
I talked with him at Skype and it was loader only he was looking for, hopefully he has managed to solve it now :)
odedshankar
Postby odedshankar » 25.07.16, 07:02
Thanks Guys, and thanks for the FW DATAMEDICS - appreciate your help. I chatted with Alyn through Skype and got the FW.
The problem was with corrupted loader, so all good, case is solved :-)
