Dear Friends ,
I have received SSD , MT-MTEE2560 256 GB SSD ,After connected in pc3000 s,Showing busy ...Please friends any can explain what i can do further ? I found little bit heat on back of ssd
any knows please tell me how check further .
Thank you
MT-MTEE2560 busy Topic is solved
Re: MT-MTEE2560 busy Topic is solved
As Far As i have seen its a mSATA interface SSD by samsung ,SSD Techno Utilities Work On The Basis of Main Controller Chip ,Please Find This Controller And See If PC 3K SSD Supports It ,Otherwise You Can Play Around With It To see if it has any electrical voltage / short issues .If indeed its the translator then brother either wait for a solution or reverse engineer it
Amarbir[CDR-Labs] wrote:Source of the post Hi,
