hi
Model : ST9500325AS
Serial : 6VEQW8NJ
Firmware : D005DEM1
Capacity : 465.76 GB (976 773 168)
when i run experess test i have red sectore like this
Set Max LBA............................. : No restriction
S.M.A.R.T............................... : Ok
Write cache............................. : enabled
Test "Express test" started
Initial LBA............................. : 0
Final LBA............................... : 976 773 167
ERROR! LBA : 107 776 Verify sectors ext error Device error detected "UNC"
ERROR! LBA : 108 032 Verify sectors ext error Device error detected "UNC"
ERROR! LBA : 108 288 Verify sectors ext error Device error detected "UNC"
ERROR! LBA : 108 544 Verify sectors ext error Device error detected "UNC"
ERROR! LBA : 108 800 Verify sectors ext error Device error detected "UNC"
ERROR! LBA : 109 056 Verify sectors ext error Device error detected "UNC"
ERROR! LBA : 109 312 Verify sectors ext error Device error detected "UNC"
i need data from hdd but in data extractor cannot access the drive
i try disk analyz but nothing
plz help me
ST9500325AS need data
- DataMedics
Re: ST9500325AS need data
Probably is a translator issue. Express test is for checking drives after you've refurbished them, not for data recovery. What are you getting in the actual terminal? Can you read sector 0 through the utility?
i know its not for recovery i just try to check sector in express test
how i can fix translate issue
in utility mod i have this
WY05A7.DEM1.DA102I.D005DEM1
Requesting FW Pkg ver ........
ID Len
0 2 Reserved Defect Table (SA defect table)
3 1870 Primary Defect File (P-List))
4 9 Servo Adaptive Parameter File (SAP)
6 85 Read Adaptive Parameters File (RAP)
8 2400
9 1 SMART Configuration File
A 2251 SMART Data File
B 1000
C 64000 Serial Port Test Results File (Self Scan Log)
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
28 80 Drive Self Test (DST), Head 6
29 80 Drive Self Test (DST), Head 7
2B 535 R/W Operating Parameters (translator, etc)
31 432 Data Integrity Check (DIC), HEAD 6
32 432 Data Integrity Check (DIC), HEAD 7
33 4576
35 26 SMART Data
Collecting DT Infos...
ID MemOffs Len
0 6020100 43520 Read Adaptive Parameters File (RAP)
1 6020000 256 Controller Adaptive Parameters File (CAP)
4 4000000 4096 Servo Adaptive Parameter File (SAP)
8 10070000 948
A 609AAA0 1024 Seek Profile
12 100D4000 104
13 60A5354 768 Dependent Zone Table for User Area
14 60A5654 64 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60A413C 4632 Dependent Zone Group Tables for User Area
1C 60A3FFC 320 Dependent Zone Group Tables for System Area
1D 6020120 208 VBAR Configuration File
1E 6020380 3216 Zone Format Parameters File
ID MemOffs Len
2 60201F0 400 Zone Table
6 1D4E40 40996 Servo Flaw Table
8 10070000 948
12 100D4000 104
16 6020100 32 Drive Configuration Table
17 6022A60 1616 Temperature Control Configuration
1F 6144678 1728 RW working user preamp table
20 6144D38 72 RW working system preamp table
Collecting DT Infos completed
ID Len
8 2400
B 1000
D 160
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
33 4576
35 26 SMART Data
ID MemOffs Len
8 10070000 948
12 100D4000 104
ID MemOffs Len
8 10070000 948
12 100D4000 104
- Amarbir[CDR-Labs]
manutd1 wrote:Source of the post i know its not for recovery i just try to check sector in express test
ID Len
8 2400
B 1000
D 160
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
33 4576
35 26 SMART Data
ID MemOffs Len
8 10070000 948
12 100D4000 104
ID MemOffs Len
8 10070000 948
12 100D4000 104
Hi ,
Seems You Are From India ,Whats Is your Location Boss
hi
im not from india
im not from india
i try read sector 0 but cannot
plz help i need data
- Amarbir[CDR-Labs]
manutd1 wrote:Source of the post i try read sector 0 but cannot
Well,
I Cannot understand a thing you said ,The only thing i can understand is sector 0 is readable
all sector is not readable, i need to recover data
- Amarbir[CDR-Labs]
manutd1 wrote:Source of the post i try this way
http://blog.acelab.eu.com/pc-3000-h ... rives.html
not working
I am Sorry but i do not think i could help you due to the fact that your english communication skills are not ok and i cannot understand much ,What i can understand though is that you are trying all stunts on this drive and intimately you will brick this case .
tnx for reply
This error shows quite early on. Can you post output from V40 command?
Users browsing this forum: Bing [Bot] and 11 guests
