ST500DM002 F/W FJK3 BUSY
redlabs
Postby redlabs » 11.06.16, 10:55
Hello Friends ...
I have ST500DM002 F/W FJK3 BUSY problem ,I have done shorting the channels and got terimal access
Rst 0x10M
MC Internal LPC Process
Spin Up
(DOS) Table Read FAIL
(DOS) Requesting File Save
No HOST FIS-ReadyStatusFlags 0002A185
ASCII Diag mode
F3 T>
ASCII Diag mode
I given command
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 1C, Max Certify Rewrite Retries = 001B
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
But still busy state .. i clear smart also without error ..after power off and ON ,Still busy not able to access the terimal and cant read the drive id
No sound from and HDD running good
Please give me solution friends
redlabs
Re: ST500DM002 F/W FJK3 BUSY
Postby redlabs » 11.06.16, 11:23
Got access
Postby Amarbir[CDR-Labs] » 14.06.16, 06:11
redlabs wrote:Source of the post Got access
More Likely it was a Saved Page Mode File Parameters Issue " Realocating Bug " .What Was The Issue i never use these M Commands much as they are never needed much
Postby AJ2008 » 24.06.16, 17:07
Probably translator fix worked but HDD takes some time to ready ready state due to relocation processes that were not disabled?
