Hello Roman ,
India Is Flooded By This Kingston UV300 Seris Drive .I Personally Have The 240GB Installed In My Computer .When Will PC 3000 SSD Support This SSD ? .
The Kingston Flood - UV300 Series
Re: The Kingston Flood - UV300 Series
It's a new generation of Kingston SSD based on Phison S10 controller if I remember. We already continue our developing in this type of CPU, and soon we will add a lot of Phison based SSD. The good thing is that Phison based SSD are very stable and it's not easy to kill them
Roman_TS wrote:Source of the post It's a new generation of Kingston SSD based on Phison S10 controller if I remember. We already continue our developing in this type of CPU, and soon we will add a lot of Phison based SSD. The good thing is that Phison based SSD are very stable and it's not easy to kill them
Hi ,
This is Good NEws ,But They Have TLC NAND Is That Not Bad Enough ?
Yes, it's true - Kingston UV300 contain TLC NAND which have bad quality. But controller PS is very good - it can make a lot of additional optimization with data, and reduce wearing of the NAND cells.
Roman_TS wrote:Source of the post Yes, it's true - Kingston UV300 contain TLC NAND which have bad quality. But controller PS is very good - it can make a lot of additional optimization with data, and reduce wearing of the NAND cells.
Hi ,
When Will The Tool Be Updated With this Controller ?
Hope that during next 3-6 month. New Utility will include a wide support of Phison based drives, that's why developers need more time before they will release it.
- dobrevjetser
Hi Roman,
When SSD equipped with TLC are bad, is it a good idea to put them in a fridge to slow down the rate at which the memory disappears, until you guys come up with a solution ?
I suppose the hotter the chips are stored, the quicker they lose their contents ?
Marc
Marc
dobrevjetser wrote:Source of the post Hi Roman,
Marc
Hello Marc. Don't worry about that - information on this SSD will stood safty for several years. We found problem with cells charge floating only in Samsung 840 EVO
I also have a Kingston HyperX Savage 240gb SSD for recovery and has Phision PS3110-S10 CPU.
Do you have any ideea if and when this CPU will be supported by PC3000?
Thank you.
Thank you.
Next Monday 11.12.2017 solution will be available for all customers who have active TS on PC-3000 software
Roman_TS wrote:Source of the post Next Monday 11.12.2017 solution will be available for all customers who have active TS on PC-3000 software
I know what is coming love you roman
