Toshiba MQ01UBF050
eisltd_adam
Toshiba MQ01UBF050
Postby eisltd_adam » 14.04.16, 10:45
Hello guys. Quick question. Which utility I can use to start this drive?
Best Regards
Adam
Re: Toshiba MQ01UBF050
Postby DataMedics » 14.04.16, 19:24
Have you adapted it to SATA? I don't think PC-3000 can work with USB Toshiba at all.
After you switch the PCB to SATA you should be able to work with it using the MQ01ABD utility.
eisltd_adam
Postby eisltd_adam » 15.04.16, 10:44
Thank you ;).
eisltd_adam
Thank you ;).
Postby Amarbir[CDR-Labs] » 18.04.16, 17:43
Hi ,
How did The Case Go ?.Can you Shed Some Light
Filipp_TS
Postby Filipp_TS » 22.04.16, 10:52
Hi to all.
What exactly is not clean regarding this case?
Also, new software version 6.1.12 is support Toshiba drives connected thru USB connection :thumbup:
Return to “Toshiba native”
