ST320LT014-9YK142 (1Ah)-TCG Serial Port Disabled
drdoc
Postby drdoc » 11.04.16, 20:39
I have been able to image the entire drive except for a section from 100million to 300 million
when i read in that area the drive gets weird lights and the dwf light comes on.
I have to repower the drive to get it to read again
its really really slow but it is reading - is there anything I can do ?
it get terminal locker message in terminal
tcg locked message
skype: wayne_horner
Alandata Data Recovery
Re: ST320LT014-9YK142 (1Ah)-TCG Serial Port Disabled
Postby Amarbir[CDR-Labs] » 13.04.16, 12:51
drdoc wrote:Source of the post I have been able to image the entire drive except for a section from 100million to 300 million
tcg locked message
Drdoc ,
I Would Like To Know Your Name First .If Its a Section Then i am Afraid Its the Platter Section Which is Weak .The Solution Would Be To Use New Heads Or clean That Platter Surface Head So That You Could See If there is Improvement in Reading .Also Try To Decrease The Block size .
