hello,
Seagate 250Gb 7200.12
firmware HP34
DRIVE SPIN WELL t> access well ,when try to erase alt list,smart, show this error Failed to load overlay 00000004,
after try to read terminal via 1b sys file, smart file not read.. if try to read show this error
F3 T>
LED:000000CC FAddr:0028848
Rst 0x08M
Rst 0x08M
solution please help..
hello, Seagate 250Gb 7200.12 firmware HP34 DRIVE SPIN WELL t> access well ,when try to erase alt list,smart, show this
Re: hello, Seagate 250Gb 7200.12 firmware HP34 DRIVE SPIN WELL t> access well ,when try to erase alt list,smart, show t
The drive isn't loading the translator. Try what's suggested in this blog post on Ace website: http://blog.acelab.eu.com/pc-3000-h ... error.html
yes we try blog video instructions, when try to load transltor, show rw error..
Check for NRG, so long as it's empty try regenerating the translator. If that fails, might be time to stick a fork in it
Also, even before that, you might give a try to reading all the critical modules through terminal using single sector read. You may find that between the two copies you'll get it all read and can assemble a complete system file that you can write back and restore it.
yes, pay attention to following critical sys files: Translator, NRGlist, Plist. Need to create a backup of them through terminal
