Head map editing in RAM for Seagate F3
pclab
Postby pclab » 09.02.16, 15:31
The topic about this issue on the Archive section have all the pictures damaged.
Can you upload them again, or do a new topic about this?
Thank You
Re: Head map editing in RAM for Seagate F3
Postby Amarbir[CDR-Labs] » 11.02.16, 14:13
pclab wrote:Source of the post Hi
Thank You
Hi PClab ,
I have done wonders with this.Specially if you are patient and can sit back and try .I have solved 2 freeplay hdds recently that had 1 of the system heads bad and out of these 2 "1" had another head also bad along with system head . Instead of jumping to using commands in terminal mode and messing the translator .i can also make a great post with this method and post if acelab can make a sticky :D
betty
Postby betty » 16.02.16, 05:01
Dear Amarbir,
Can u explain in Detail how did u do it from " head damaged I have solved 2 freeplay hdds recently that had 1 of the system heads bad and out of these 2 "1" had another head also bad along with system head . Instead of jumping to using commands in terminal mode and messing the translator" .
betty
crystal
Postby Amarbir[CDR-Labs] » 17.02.16, 11:51
betty wrote:Source of the post Dear Amarbir,
betty
crystal
Hi ,
I Have Always Wondered If Betty is a - or a Boy .Anyway I Will Prepare This Tutorial And Post it Online
betty
Postby betty » 03.03.16, 06:40
Hai amarbir,
I have got one hdd and it is getting spin down after few minits of power start. I have done head map and head "0" disabled. and now it spinning with drd and dsc. but no capacity also not able to access the system files through terminal. Any solution ,pls share... also i giving below the terminal output:
RECOV Servo Op=0055 Resp=0005[LBA=0x00028F1D]N02010C10o0o0o0o0o0o0o0o0[LBA=0x00028F1D]NO1111
RECOV Servo Op=0155 Resp=0005[LBA=0x0008BA5F]N
Trans.
Spin Up
SpinOK
TCC:0020
SNOOOZZZZZZEEE Retry
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
RECOV Servo Op=0165 Resp=0005
(P) SATA Reset
ASCII Diag mode
F3 T>/1
F3 1>N1
RECOV Servo Op=0065 Resp=0005
Clear Current Device Internal Status Log
Clear Saved Device Internal Status Log
Clear SMART is completed.
F3 1>
betty
crystal
Users browsing this forum: gautam.dotcom and 12 guests
