HDD ST3360320AS is recognized as a ST340815A no data access
eisltd_adam
Postby eisltd_adam » 01.02.16, 16:35
Hi guys. I have such a problem. On the PCB, diod was burned. After replacing it HDD starts no problem. That is what I have in terminal. I can't access data at all. Any idea?
T>Reset
4096k x 16 DRAM
GALAXY - 1_Disk S-7A 05-08-07_12:23
HM SFI
(P)SATA Reset
AT Er 00 Nwt Er 37 RdWr 00019.00.0012
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 0000058c 18 0000058c.0.096 8000 0640 ffff 0000
DiskAccess ReadSector EC=43 at 000019.00.0012
CE Log ErrCode=37 LBA=58c Type=5 Add To Pending 58c
Re: HDD ST3360320AS is recognized as a ST340815A no data access
Postby DataMedics » 01.02.16, 17:41
First off are you sure it's an original PCB? If it's recognizing as a completely different model, that's the first thing I'd suspect.
eisltd_adam
Postby eisltd_adam » 01.02.16, 17:44
Yes, it is original. I have full ID, I can read rom and all modules. Some times it is complaining about not loaded cert. If i click load cert it will find it and load.
Nick_TS
Postby Nick_TS » 08.02.16, 21:06
Can read app code by terminal?
Return to “Arch ST10”
