PC-3000 is compatible with Windows 10 Topic is solved
Filipp_TS
Postby Filipp_TS » 11.01.16, 16:10
ACE Lab has successfully conducted the OS Windows 10 compatibility tests for the PC-3000.
All the PC-3000 products with the latest software versions can be installed on the Windows 10 OS platform.
For all the PC-3000 products, the digital signatures of executable files have been added:
for the PC-3000 kernel
for the installation file
The files are signed by Verisign ACE Lab certificate.
When each of the executable files is launched on the OS Windows 7, 8, and 10, the operation system checks for availability and validity of the digital signature. If the signature is valid, then administrative access is requested to the software published by “ACE Scientific Production Enterprise Limited”.
If the software publisher is set as “unknown publisher” it means that the executable file was modified or damaged.
Note: Downloading executable files from the Internet without the digital signature is quite difficult on the OS Windows.
Re: PC-3000 is compatible with Windows 10
Postby DataMedics » 13.01.16, 19:50
Good to know this. I know a few guys already running it, and I've been thinking of upgrading my Express station too. I've just been a bit hesitant as rolling back is sure to be a total nightmare.
pclab
Postby pclab » 17.01.16, 15:51
Got my new UDMA-E working on windows 10. No problems so far...
day1data
Postby day1data » 19.01.16, 09:40
Same here.
Both PC3K and Flash are working fine on Windows 10 64bit.
lcoughey
Postby lcoughey » 19.01.16, 16:32
I've been running on Windows 10 for one of my four PC3K systems for a couple months and will likely upgrade the rest before too long.
osity
Postby osity » 26.01.16, 16:35
Why would you want to run windows 10 over 7?
I don't see a benefit other than maybe faster boot time.
Postby DataMedics » 27.01.16, 00:26
I just did my upgrade this afternoon and can confirm all seems to be working well.
osity wrote:Source of the post Why would you want to run windows 10 over 7?
I actually like Win 10 (once you convert coretana to use google instead of Bing). I like that the start menu and task bar are now available on each display. I also find that drives become available much faster when you hot connect them over windows 7, and it's less prone to crashing out when you do hot swap drives (which happens pretty often here).
Postby Amarbir[CDR-Labs] » 30.04.16, 09:17
DataMedics wrote:Source of the post I just did my upgrade this afternoon and can confirm all seems to be working well.
Jared ,
I Have a DFL SRP :All In One Connected To The Main PC I Have PC 3000 UDMA e Installed ,Its a Socket 775 Quad Core Extreme Processor That i Have Been Using Since a Long Time .This PC Is Installed With Windows 7 32Bit OS And Is Very Prone To Crashes .I Am Planning To Update The BIOS And Dismentle The PC And Clean Install It Again .If It Starts Behaving Properly Then Fine Otherwise i Will Update It Completely But i Am Not Sure Of The OS Update
digiforin
Postby digiforin » 16.08.16, 13:31
Today I updated Windows 10 Pro x64 from version 1511 to version 1607 (feature update for windows 10). Now I have problem with PC3000 UDMA-E controller - it is not recognized by OS. I tried update the drivers but without results - "Windows encountered a problem installing the driver software for your device". If there is no solution of Acelab then I will need go back to version 1511 :shockable:
P.S. I have a PC3000 UDMA Express, version 5.8.14.
The new information (23.09.2016).
We upgraded our PC3000-E from ver. 5.8 to ver. 6.1, and also Windows 10 ver. 1511 to ver. 1607. All works fine :thumbup:
Postby DataMedics » 16.08.16, 19:38
Good to know that. I'm at version 1511, I guess I'll stick with it for a bit and not do any more updates until it's resolved. Anyone else had this issue?
pclab
Postby pclab » 17.08.16, 14:29
Mine is updated to the latest version (don't know now which right now), and still everything OK.
Filipp_TS
Postby Filipp_TS » 02.09.16, 11:02
digiforin wrote:Source of the post Today I updated Windows 10 Pro x64 from version 1511 to version 1607 (feature update for windows 10). Now I have problem with PC3000 UDMA-E controller - it is not recognized by OS. I tried update the drivers but without results - "Windows encountered a problem installing the driver software for your device". If there is no solution of Acelab then I will need go back to version 1511 :shockable:
5.8.14 software version is to old..
Win 10 is officially compatible with PC-3000 software since 6.1 utility version (for UDMA-E, Express, Portable) and 7.0.4 (for Flash)
Postby Amarbir[CDR-Labs] » 02.09.16, 12:04
Filipp_TS wrote:Source of the post
Filip,
Never knew 7.0.4 is the one compatible with win 10,I though flash was compatible to it long time back
Postby Roman_TS » 05.09.16, 09:05
Amarbir[CDR-Labs] wrote:Source of the post Never knew 7.0.4 is the one compatible with win 10,I though flash was compatible to it long time back
You can work with PC-3000 Flash and Win 10 starting from Flash 7.0.1, but stable driver and full optimization appear only in 7.0.3 - 7.0.4 versions
Return to “News”
