Toshiba DT01xxxx series
jerovsek
Postby jerovsek » 04.01.16, 13:53
which which family to select for DT01xxxx
Filipp_TS
Re: Toshiba DT01xxxx series
Postby Filipp_TS » 11.01.16, 12:23
try to use 7210DLE6 family.
Imnew
Postby Imnew » 30.01.16, 08:44
Hello Filipp.
I have same case. The HDD is Toshiba DT01ACA050. I have chosen 7210DLE6 family from Hitachi. I can read all the modules. But it is not allowing to image or not allowing to read data area. Please help
drdoc
Postby drdoc » 30.01.16, 10:39
Model : TOSHIBA DT01ACA100
Serial : Y3J1MH1MS
Firmware : MS2OA750
Capacity : 931.51 GB (1 953 525 168)
PC3K V6
it doesnt detect family, wont read modules UNLESS I try family 5C10CLA3 first
Selected family......................... : 7210DLE6
Model by ID............................. : TOSHIBA DT01ACA100
PCB only start!
PCB only start!
Error reading module USAG(0): PCB only start!
PCB only start!
PCB only start!
Error reading module USAG(1): PCB only start!
Error : .............................................................. : Module USAG: no copies read!
Error : .............................................................. : PCB only start!
========== Here I try 5C10CLA3 first, then 7210DLE6 works
Selected family......................... : 5C10CLA3
Techno mode key......................... : Error
Loading the table of "open" modules................................... : Ok
skype: wayne_horner
Alandata Data Recovery
Postby DataMedics » 30.01.16, 13:39
I guess that answers which Techno mode key it needs. You may have just helped Ace with this one. Good find!
Filipp_TS
Postby Filipp_TS » 02.02.16, 14:56
Hello Everybody,
If you still have a problem with solutions for these hitachi drives please contact Technical support dept: ts.acelab.eu.com
and we are check these cases detailed.
vijayan
Postby vijayan » 12.02.18, 10:27
Yes Now
Same Case Solved Toshiba Hard Disk Toshiba Famliy Not Seleted Hitech Famliy Seleted Working Full Data Imaging Complied
TOSHIBA DT01ACA100.JPG (3.07 KiB) Viewed 18026 times
Best regards,
Vijayan MBA
Raminfotech Data Recovery
call 7092114411/22
sky:raminfotech.vijayan
whatup:9841983643 / 46
Filipp_TS
Postby Filipp_TS » 20.02.18, 12:47
Because of DT**** toshiba drives are not Toshiba drives actually.
They are have Hitachi architecture, that's why for all DT*** drives need to use Hitachi ARM utility.
Postby Amarbir[CDR-Labs] » 25.02.18, 08:55
Its a hitachi drive period and you need to select " Tech Key " selection and unstick pcb only if thats selected ,Thats it you do not need to select any other family before this ,tech key detection is the key to this
