1) lost of readiness on UDMA66 mode
2) lost of readiness on other modes
+ i am strongly want this option:
"[ ] stop the process and poweroff the drive"
This is why some of the drives needs soft reset only in UDMA mode (or don't need nothing in this mode) and i need to powerdown to prevent the drive from scratching but only in low-level modes, when the drive really losts readiness.
Additionally aggre with others, on the MAP view, the clicking to the LBA with right click, it should be more items, especially to select the state (forced green or similar)
I had one case wich had UNC in the extended partiton's table, but i have-re created the sector by hand, but there is no way to force the DE to use this sector from the target drive except manually hack into the map file.
Thanks,
Janos
