Kingston Data Travel 16gb recovery
Typical Flash recovery cases
FranZ74_DR
Postby FranZ74_DR » 01.12.15, 15:31
I have a problem with Kingston 8gb flash case recovery. Controller name SSS6698, two chips 0x98DE9892 8gb each. I would like to recover folder structure - is it possible? I perform XOR, page transformation, mix, get a lot of good data in RAW, but I want to build image. How can I do that?
Similar solution:
http://www.pc-3000flash.com/solbase/sol ... 5&lang=eng
Nick_TS
Re: Kingston Data Travel 16gb recovery
Postby Nick_TS » 01.12.15, 16:23
There is no marker in service area so it's impossible to recover data by block number.
Also there is translator but it's encrypted so we can't recover via translator too.
I see raw recovery only.
Have a nice day.
FranZ74_DR
Postby FranZ74_DR » 01.12.15, 17:05
That's a pity. Are you guys have a plan to add translator in PC3K Flash for this controller? Those chips appears several years ago, and customer who gave this UFD to me bought it in 2013!
Postby Roman_TS » 02.12.15, 10:11
Hi! We have a problem with current translator. Unfortunately it really very wired, maybe later this algorithm will appear in our software, but for now, the only way to get access to user data - RAW Recovery :(
As I remember, current family of controllers - SSS6696, SSS6697, SSS6698 - the only controllers which have problem with image building...
FranZ74_DR
Postby FranZ74_DR » 03.12.15, 08:26
ok, got it, thanks
Postby Amarbir[CDR-Labs] » 30.04.16, 09:54
FranZ74_DR wrote:Source of the post I have a problem with Kingston 8gb flash case recovery. Controller name SSS6698, two chips 0x98DE9892 8gb each. I would like to recover folder structure - is it possible? I perform XOR, page transformation, mix, get a lot of good data in RAW, but I want to build image. How can I do that?
Similar solution:
Hello Sir ,
Can You Share The Image of This Case "Real Photo " . Have To Seen Other Tools Working Properly With This Controller And The Controller Roman Sir Was Referring to
