Need Rom SSHD ST1000LM014 Fw: LIV6
moyug
Postby moyug » 20.10.15, 09:54
I'm looking for a Rom for sshd ST1000LM014 Fw Lenovo: LIV6.
Re: Need Rom SSHD ST1000LM014 Fw: LIV6
Postby AJ2008 » 20.10.15, 10:34
the ROM is unique and cannot be replaced. Did you check terminal window on powering of this? Does it display any info?
Postby AJ2008 » 12.11.15, 11:29
Did you solve this case? Also, do you mean FW of 'LVD6' ? If you can report here terminal output and it relates to 'clumps' error I have a solution for it that I may be able to help with.
momentus
Postby momentus » 12.11.15, 11:57
Hello , I have Seagate SSHD , with clumps error. Do You know how to make it run ?
Postby AJ2008 » 12.11.15, 12:02
I cannot repair the error in the NAND, but I do know how to reach user data. The NAND contains a copy of the ROM and some SA info, so it is impossible to use donor PCB as donor NAND has donor ROM inside and will always boot first. The NAND at the donor PCB needs to be emptied and patient ROM needs to be loaded to it. This I can do.
What is the details of your drive?
momentus
Postby momentus » 12.11.15, 12:26
It is ST1000LM014 firmware LVD1. Drive doest`t spin up. In terminal You have this "clumps" error and BSY register. I have the same donor drive. I tried to put board from donor and drive start spinning, heads recalibates properly. Of course ROM was from donor drive so I didn`t have access do the user data. I read ROM from "damaged clumps" board and write it into donor board but after that drive doesn`t spin again no info about clumps. You suggest to write whole ROM or a part of it into donor ? Am I understad it right ?
Postby AJ2008 » 12.11.15, 12:28
Donor PCB is from drive with different FW version? Donor must have same FW version to ensure similar NAND structures.
I will message you with my skype, it will be easier to talk there
momentus
Postby momentus » 12.11.15, 12:46
Donor firmware and damaged are the same LVD1 (I already skype You )
moyug
Postby moyug » 30.11.15, 16:04
Hello AJ2008,
Sorry for delay, yes this case is solved.
It was an adaptive problem.
300ddr
Postby 300ddr » 20.01.16, 00:01
AJ2008 wrote:The NAND at the donor PCB needs to be emptied and patient ROM needs to be loaded to it. This I can do.
Can anyone explain how to do this on PC3K?
igen
Postby igen » 22.01.16, 09:48
AJ2008 !
You wrote, that:
" The NAND at the donor PCB needs to be emptied and patient ROM needs to be loaded to it. This I can do. "
Please write, how to do it.
Marcus Tullius Cicero
