toshiba DT01ACA100
datasolution
toshiba DT01ACA100
Postby datasolution » 23.09.15, 09:57
HELLO TO ALL,
I HAVE RECEIVED 1TB TOSHIBA.UNABLE TO CHECK DATA AREA.DATA AREA NOT ACCESS.
Techno On............................... : Device Error Detected 51/04 (ABR)
Zone table.............................. : Zone table read error; Device Error Detected 51/04 (ABR)
G-List reading error.................... : G-List read error; Device Error Detected 51/04 (ABR)
CP Avalable............................. : 20,23,33,34,44,56,92,95,98,9A,9B,9C,A2,A5,A7,A8,A9,AA,AD,AE,AF,B1,B3,B5,B6,BB,C1,C4,C5,C6,C7,C8,C9,CA,CB,CD,D1,D4,D6,D7,D8,D9,DA,DB,DD,E0,E1,E2,E3,E4,E5,E6,E7,E8,E9,EF,F1,F2,F4,F7
Techno ON............................... : Device Error Detected 51/40 (UNC)
CP Reading error; Device Error Detected 51/04 (ABR)
Translator initialization error. Cleared translator will be used!
ECC ON error; Device Error Detected 51/04 (ABR)
Data access mode setting................ : UDMA 33
Data access mode setting................ : PIO
CAN ANYBODY TELL ME HOW DO I CONNECT TERMINAL.TO GET DATA ACCESS.
surgeryhdd
Re: toshiba DT01ACA100
Postby surgeryhdd » 13.07.18, 19:17
Hi, your problem is not correct?
Takanashi_Hina
Postby Takanashi_Hina » 13.07.18, 21:09
DT01ACA100
HGST ... NOT TOSHIBA.
Try Hitachi 7210DLE6 ARM Utility
:oops: :oops: :oops:
cosborn
Postby cosborn » 23.01.20, 18:35
I have the exact same situation with the exact same model drive. I just tried using the Hitachi 7210DLE6 utility without success. I seem to have similar issues with many of the Toshiba drives in general. Would anyone happen to have a solution to this? I've included an image of the label in the hope that it will help find a solution. (Apologies if this has already been addressed. New to this and I haven't found a solution on the forum from my searches so far.)
