Hello, I have HDD Model ST320LT020. The HDD is spinning normally but not identified. Only PCB shows Model/Sl. No./FW.
The HDD in terminal gives the following continuous message :
ASSERT_ID_00009658
LED:000000CC FAddr:00352BC7
Rst 0x10M
(P) SATA Reset
ASSERT_ID_00009658
Rst 0x10M
(P) SATA Reset
ASSERT_ID_00009658
Rst 0x10M
(P) SATA Reset
ASSERT_ID_00009658
Rst 0x10M
(P) SATA Reset
Can someone help me in this case. Thanks
HDD model ST320LT020 not identified
Re: HDD model ST320LT020 not identified
You would need to short it to retain access to T>. IF not, maybe you should isolate then spin down/up to keep T>. Only then you can start to work out what is wrong.
I would guess overlays are not loading for some reason or maybe translator is bad, but to know for sure you need to look more into it with access to SA/Terminal.
