hi
i have h.d.d 500 7200.12
f/w: kc45
this is do detect but no id
when run utility start on led ABR
i do test head
- edit id from terminal
- i do short pin
this output terminal :
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
RAW OFF
PASS
MCMTFileHandler: EXCEPTION: Failed MCMT read request
what is MCMT?
plz help me ?
mcmt
Re: mcmt
MC = MEdia cache. For this it seems like there is problem with Media Cache and you need to disable it. You can do this with system file '0x93'. After it is cleared try again, but there may be some error with the MC bitmap.
Remove MC options via 0x93 then report here behaviour.
Re: mcmt
Have you gone back to confirm that your changes to module 93 wrote to the drive?
