hi
ive got a ST1000333AS and it is just busy
both tried short connect and isolating PCB
and sill cannot appear F3 T>/
here is the code
Rst 0x20M
LED:000000CD FAddr:00010303
ST1000333AS busy problem with led:00000cd err
- jasminehell
Re: ST1000333AS busy problem with led:00000cd err
T> should be ok on this without need to short circuit. What is FW version?
- jasminehell
AJ2008 wrote:T> should be ok on this without need to short circuit. What is FW version?
it is cc1f,and im lookin for a same hdd.
does hot swap work?
HotSwap wont work.
IF you place paper to isolate heads from PCB and wait some time, it should reach ready with T> access. What happens if you isolate and wait for it?
- jasminehell
when i isolating PCB,no code.and it seems it's ready.
but when ctrl+z ,nothing happens.
