Why capacity size is different from final LBA?
A few times, here is an example:
750GB toshiba drive,
capacity size: 1 465 149 167
Final LBA: 183 143 645
What relationship for these two number?
Most of time/Drives they are the same.
Thanks.
Phil
ps: DE does clone the total capacity size of 750GB hard drive, just the different number confuse.
Re: Why capacity size is different from final LBA?
Probably 4K vs 512 byte sector
AJ2008 wrote:Probably 4K vs 512 byte sector
AJ,
Thanks a lot, yes, it should be, as time 8 and get the correct results.
Phil
I have next steps to try:
1. Go to utility and check Tools->Drive ID. It will tell you sector physical size.
2. Try setting this sector size within Data Extractor task by right clicking on a partition and using "Set sector size".
